مشکل در اتصال به sql server2014
بپرسید
سلام وقتی میخوام به sql server وصل بشم با اخطار زیر روبه رو میشم
TITLE: Connect to Server
Cannot connect to ..
ADDITIONAL INFORMATION:
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server) (Microsoft SQL Server, Error: 2)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft%20SQL%20Server&EvtSrc=MSSQLServer&EvtID=2&LinkId=20476
The system cannot find the file specified
BUTTONS:
OK
پاسخ ها به این سوال
پاسخ ها به این سوال
{{ digitTrunc(post.likes) }}
{{ err }}
